deform 复合挤压没算完就停止了,请问如何修改参数? 22
浏览:1597 回答:1
 Fatal Error in polygon search in CNTINF
  Please report this to SFTC.
  ...Object(Boundary)   =   4
  ...Node number        =   2084
  ...Contact die number =   1
 The following nodes of Obj.  4 have contacted Die  1
   1561   1564   1565   1576   1648   1667   1669   1708   1725   2011
Ignored contact of Node#   1917 of Obj.  4 from Die #  1
 because of far distance or ruining neighboring element(s).
 Node    1389 of Obj.  4 has contacted the symmetry plane.
  RSE: Contact between deforming objects
  RSE routine will not be activated
job aborted:
rank: node: exit code[: error message]
0: DESKTOP-9H4B51P: -1073741819: process 0 exited without calling finalize
1: DESKTOP-9H4B51P: -1073741819: process 1 exited without calling finalize
只有22个金币,散尽求解答
lemonemon
您好,我也遇到了同样的情况。模拟未完成程序就自动停止,请问解决了吗,感谢
2021年9月3日
