pamcrash运行过程中报错? 20
浏览:1323 回答:1
| 11) MATERIAL TYPE 301 WITH FAILURE AND ZERO DISTANCE        |
| 12) NODE ID USED FOR MORE THEN ONE RBODY COG                |
|  V2005:                                                     |
| 13) EMPTY KEYWORD SELECTION FOR TIED INTERFACE              |
| 14) TIED INTERFACE FAILED TO ESTABLISH A CONNECTION         |
| 15) IMPROVEMENTS ON COMPOSITE DAMAGE WITH INPUT MODIFICATION|
| 16) CONSISTENCY OF ACFLD SUBTRACTION FOR THLOC OUTPUT       |
| 17) ADDED MASS ON COG NODE OF RBODY TYPE 0                  |
| 18) ADDED MASS ON COG NODE OF MBSYS RBODY TYPE 1            |
| 19) ACFLD and DAMP DEFINED ON ALL NODES OF RBODY TYPE 0     |
| DATACHECKS 1, 2, 3, 4 AND 5 CAN BE SWITCHED OFF. HOWEVER,   |
| THEIR USE IS STRONGLY RECOMMENDED TO IMPROVE THE MODEL.     |
| SWITCHING OFF DATACHECK MAY CAUSE WRONG, UNRELIABLE AND     |
| UNSTABLE RESULTS.                                           |
     OPTIONS USED :
                      1.  ANALYSIS     : EXPLICIT
                      2.  SOLVER       : CRASH
                      3.  UNIT         : M       KG        S   KELVIN
***** PROBLEM IN ASCII INPUT FILE : MAIN INPUT FILE
***** AT LINE :     16 FATAL READING ERROR (192700), PLEASE CHECK INPUT FILE
*****  END RUN CRITERION EXPECTED
     *** ERROR *** OCCURRED IN INPUT PHASE, SEE ABOVE
这个报错是什么原因?
技术邻问答
@王毅
2017年10月13日
