怎么解决abaqus材料定义的问题?
浏览:3602 回答:2
Error in job s1: Anisotropic material properties without a local orientation system have been defined for 8000 elements. Anisotropic material properties must be defined in a local orientation system. The elements are identified in element set ErrElemAnisotropicMaterial.
提交之后显示了这个,在之前设置材料属性的时候设置的各项同性,但这里为什么提出了各项异性?还有应该如何解决?
谢谢
