在matlab调用abaqus出现了问题,怎么解决? 70
浏览:2232
在matlab里输入system(['abaqus ','job','=E:\文件名']),然后就出问题了,问题如下:Abaqus Error: Unable to create a temporary directory "C:\Windows\TEMP\Administrator_E:\intial_6528" to be used for scratch files.
如果输入system(['abaqus ','job','=文件名'],不加路径,那么提示
Abaqus Error: Command line option "input" must have a value.
Abaqus/Analysis exited with error(s).
求大神解决
