ansys材料属性的本构模型设置? 50
浏览:2430 回答:2
我定义钢材的本构模型:
TB,MISO,1,1,13
TBPT,,149.883 ,1.41529E-06
TBPT,,258.782 ,0.000531556
TBPT,,327.869 ,0.006936151
TBPT,,332.553 ,0.008090836
TBPT,,336.066 ,0.009068476
TBPT,,353.63  ,0.0157654
TBPT,,380.562 ,0.034973202
TBPT,,402.81  ,0.064802329
TBPT,,418.033 ,0.096933682
TBPT,,428.571 ,0.12701227
TBPT,,436.768 ,0.156014263
TBPT,,441.452 ,0.175167644
TBPT,,443.794 ,0.185523503
出现错误:
*** WARNING ***                         CP =       1.934   TIME= 20:05:06
 The point 258.782, 5.31556E-04 is off the end of the MISO table and is
 not inserted.
 *** WARNING ***                         CP =       2.137   TIME= 20:05:07
 The point 327.869, 6.936151E-03 is off the end of the MISO table and is
 not inserted.
 *** WARNING ***                         CP =       2.480   TIME= 20:05:08
 The point 443.794, 0.185523503 is off the end of the MISO table and is
 not inserted.
这是为什么呢,有哪位大神有解决的办法?
蓝牙
按照楼上提取的结果,以及你的报错信息,是本构插值没有成功,检查是不是应力应变关系定义错了! 你好像把应力的位置放了应变
2017年11月18日
已采纳 评论 点赞
大龙猫🐱
你复制下面的命令粘贴进去,结果是没有问题,可能你的标点符号有点问题
TB,MISO,1,1,13
2017年11月17日
已采纳 评论 点赞
