abaqus做仿真提示的错误? 1760
浏览:3037 回答:13
Abaqus中先算螺栓预紧力后算冲击,如何设置如下:
1. 我是先用general static分析步算螺栓预紧力的,算完之后改成dynamic explicit分析步进行求解,请问这个思路是对的吗?
2. 在求解螺栓预紧力的时候我也设置了restart
3. 算完之后的文件如下:
4.然后另存模型,修改分析步为dynamic explicit,删除load边界条件,也就是螺栓预紧力,还修改了model attributes和load 模块里面的predifined filed
4.job里面是这样设置的:
5.提交计算提示错误
The slave surface assembly_part21-1_surf-igbt-base does not exist.
Surface assembly_part21-1_surf-igbt-base not found
Contact pair references surface/node-based surface/analytical rigid surface assembly_part22(dizuo)-1_surf-base-cooler but this surface/node-based surface/analytical rigid surface has not been defined or this surface is defined on the collapsed faces
Contact pair references surface/node-based surface/analytical rigid surface assembly_part1-1_surf-cooler-base but this surface/node-based surface/analytical rigid surface has not been defined or this surface is defined on the collapsed faces
Contact pair references surface/node-based surface/analytical rigid surface assembly_part22(dizuo)-1_surf-base-1 but this surface/node-based surface/analytical rigid surface has not been defined or this surface is defined on the collapsed faces
Contact pair references surface/node-based surface/analytical rigid surface assembly_bolt-1_surf-bolt-base but this surface/node-based surface/analytical rigid surface has not been defined or this surface is defined on the collapsed faces
Contact pair references surface/node-based surface/analytical rigid surface assembly_part22(dizuo)-1_surf-base-2 but this surface/node-based surface/analytical rigid surface has not been defined or this surface is defined on the collapsed faces
Contact pair references surface/node-based surface/analytical rigid surface assembly_bolt-2_surf-bolt-base but this surface/node-based surface/analytical rigid surface has not been defined or this surface is defined on the collapsed faces
Contact pair references surface/node-based surface/analytical rigid surface assembly_part22(dizuo)-1_surf-base-3 but this surface/node-based surface/analytical rigid surface has not been defined or this surface is defined on the collapsed faces
Contact pair references surface/node-based surface/analytical rigid surface assembly_bolt-3_surf-bolt-base but this surface/node-based surface/analytical rigid surface has not been defined or this surface is defined on the collapsed faces
Contact pair references surface/node-based surface/analytical rigid surface assembly_part22(dizuo)-1_surf-base-4 but this surface/node-based surface/analytical rigid surface has not been defined or this surface is defined on the collapsed faces
Contact pair references surface/node-based surface/analytical rigid surface assembly_bolt-4_surf-bolt-base but this surface/node-based surface/analytical rigid surface has not been defined or this surface is defined on the collapsed faces
Contact pair references surface/node-based surface/analytical rigid surface assembly_part22(dizuo)-1_surf-base-5 but this surface/node-based surface/analytical rigid surface has not been defined or this surface is defined on the collapsed faces
Contact pair references surface/node-based surface/analytical rigid surface assembly_bolt-5_surf-bolt-base but this surface/node-based surface/analytical rigid surface has not been defined or this surface is defined on the collapsed faces
Contact pair references surface/node-based surface/analytical rigid surface assembly_part22(dizuo)-1_surf-base-6 but this surface/node-based surface/analytical rigid surface has not been defined or this surface is defined on the collapsed faces
Contact pair references surface/node-based surface/analytical rigid surface assembly_bolt-6_surf-bolt-base but this surface/node-based surface/analytical rigid surface has not been defined or this surface is defined on the collapsed faces
Analysis Input File Processor exited with an error.
该怎么办呢?我定义接触了啊,看了一下都没有问题
求各位大神指点一二,在此拜谢!
(10)
喻小泉
要在装配体里重新建立表面,将部件里的表面删掉
2023年12月14日
评论 点赞 1
林丽
不是 应该就是你用的这个predefined field, 只是你要分开成两个cae文件来做,不是在同一个里面。你先计算第一步,得到的odb文件里面的应力分布作为第二步dynamic分析的初识应力场。
2017年11月22日
评论 点赞 1
走过繁华四季的美好
你这个是面定义的有问题,不连续的不能选,接触要分开定义,我遇到过这样的错误,有问题可以加我qq交流
2017年12月10日
已采纳 评论 1 点赞
林丽
不是重启动分析
2017年11月22日
善哉善哉
@一只攻城狮
2017年11月22日
善哉善哉
@ 一只攻城狮
2017年11月22日
善哉善哉
@ 一只攻城狮
2017年11月22日
善哉善哉
@一只攻城狮,是这样的吗
2017年11月22日
善哉善哉
是这样的吗
2017年11月22日
林丽
不是用restart 要用import 或者都用dynamic的分析方式啊
2017年11月22日
