abaqus出现以下错误,应该怎么解决?
浏览:1814 回答:2
The executable pre.exe aborted with system error code 1073741819. Please check the .dat, .msg, and .sta files for error messages if the files exist.  If there are no error messages and you cannot resolve the problem, please run the command "abaqus job=support information=support" to report and save your system information.  Use the same command to run Abaqus that you used when the problem occurred.  Please contact your local Abaqus support office and send them the input file, the file support.log which you just created, the executable name, and the error code.
cae在路上
你这个是算什么,这个我是在算接触的时候碰到过
2017年12月16日
HYT
断了wifi. 用abaqus的时候不要联wifi
2017年12月15日
