ANSYS Workbench 问题
浏览:2753 回答:1
Solver pivot warnings or errors have been encountered during the solution.  This is usually a result of an ill conditioned matrix possibly due to unreasonable material properties, an under constrained model, or contact related issues.  Check results carefully.
在做结构静力学分析时一直遇到这个问题····求问大神如何
liyang617730
检查材料设置,看看单位或者数量级有没有搞错.接触刚度也可以调整,试试不同的接触方式,刚度太大了也很难收敛。还有就是约束施加,点,线,面约束?还是单元,节点约束,总之约束自由度要全
2017年12月28日
