ABAQUS问题? 120
浏览:3325 回答:4
我用的是UMAT子程序,出现以下问题:
The executable standard.exe aborted with system error code 1073740940. Please check the .dat, .msg, and .sta files for error messages if the files exist.  If there are no error messages and you cannot resolve the problem, please run the command "abaqus job=support information=support" to report and save your system information.  Use the same command to run Abaqus that you used when the problem occurred.  Please contact your local Abaqus support office and send them the input file, the file support.log which you just created, the executable name, and the error code.
这是dat文档中的内容:
   Abaqus 6.14-1                                  Date 19-一月-2018   Time 10:56:46
   For use by Supplied By SSQ under license from Dassault Systemes or its subsidiary.
                         The Abaqus Software is a product of:
                           Dassault Systemes Simulia Corp.
                                 Rising Sun Mills
                                 166 Valley Street
                           Providence, RI 02909-2499, USA
                   The Abaqus Software is available only under license
                   from Dassault Systemes or its subsidiary and may be
                   used or reproduced only in accordance with the terms
                   of such license.
                          On machine Shisy
                          you are authorized to run
                          Abaqus/Standard until 31-Dec-2055
                          Your site id is:
                    For assistance or any other information you may
                    obtain contact information for your local office
                    from the world wide web at:
                      http://www.3ds.com/products/simulia/locations/
                *                   *  N O T I C E  *                     *
                *                    Abaqus 6.14-1                        *
                *          BUILD ID: 2014_06_05-06.11.02 134264           *
                *  Please make sure you are using release 6.14 manuals    *
                *  plus the notes accompanying this release.              *
     PROCESSING PART, INSTANCE, AND ASSEMBLY INFORMATION
     END PROCESSING PART, INSTANCE, AND ASSEMBLY INFORMATION
     OPTIONS BEING PROCESSED
  *Heading
  *Node
  *Element, type=C3D8R
  *Nset, nset=ASSEMBLY_PART-1-1_SET-1
  *Nset, nset=ASSEMBLY_PART-1-1_SET-3
  *Elset, elset=ASSEMBLY_PART-1-1_SET-1
  *Elset, elset=ASSEMBLY_PART-1-1_SET-3
  *Node
  *Nset, nset=ASSEMBLY_M_SET-1
  *Nset, nset=ASSEMBLY_SET-2
  *Nset, nset=ASSEMBLY_SET-3
  *Elset, elset=ASSEMBLY_SET-2
  *Elset, elset=ASSEMBLY__S_SURF-1_S3
  *surface, type=ELEMENT, name=ASSEMBLY_S_SURF-1
  *coupling, constraintname=ASSEMBLY_CONSTRAINT-1, refnode=ASSEMBLY_M_SET-1, surface=ASSEMBLY_S_SURF-1
  *kinematic
 ***WARNING: WHENEVER A TRANSLATION (ROTATION) DOF AT A NODE IS CONSTRAINED BY
             A KINEMATIC COUPLING DEFINITION THE TRANSLATION (ROTATION) DOFS
             FOR THAT NODE CANNOT BE INCLUDED IN ANY OTHER CONSTRAINT INCLUDING
             MPCS, RIGID BODIES, ETC.
  *material, name=ZICHENGXU
  *depvar
  *usermaterial, constants=88
  *material, name=ZIDAI
  *density
  *elastic
  *concretedamagedplasticity
  *concretecompressionhardening
  *concretetensionstiffening
  *solidsection, elset=ASSEMBLY_PART-1-1_SET-3, controls=EC-1, material=ZICHENGXU
  *sectioncontrols, name=EC-1, hourglass=ENHANCED
 ***WARNING: THE PARAMETER HOURGLASS = ENHANCED ON THE SECTION CONTROLS OPTION
             IS RELEVANT FOR THESE ELEMENTS: C3D8R, CAX4R, CGAX4R, CPEG4R,
             CPE4R, CPS4R, M3D4R, S4R, SC8R AND THEIR HYBRID, THERMAL AND
             PRESSURE COUNTERPARTS WHEREVER APPLICABLE. IT IS ALSO RELEVANT FOR
             ALL TYPES OF MODIFIED TRIANGULAR AND TETRAHEDRAL ELEMENTS. THIS
             WARNING CAN BE IGNORED IF THE FEATURE IS APPLIED TO THESE ELEMENT
             TYPES ONLY.
  *boundary
  *boundary
  *output, field, variable=PRESELECT
  *output, history, variable=PRESELECT
 ***WARNING: MPCS (EXTERNAL or INTERNAL, including those generated from rigid
             body definitions), KINEMATIC COUPLINGS, AND/OR EQUATIONS WILL
             ACTIVATE ADDITIONAL DEGREES OF FREEDOM
  *amplitude, name=AMP-1
  *Step, name=Step-1, nlgeom=NO, inc=10000
  *static
  *boundary
  *boundary
  *endstep
  *static
  *boundary
  *boundary
  *endstep
                            P R O B L E M   S I Z E
          NUMBER OF ELEMENTS IS                                    90
          NUMBER OF NODES IS                                      177
          NUMBER OF NODES DEFINED BY THE USER                     177
          TOTAL NUMBER OF VARIABLES IN THE MODEL                  582
          (DEGREES OF FREEDOM PLUS MAX NO. OF ANY LAGRANGE MULTIPLIER
           VARIABLES. INCLUDE *PRINT,SOLVE=YES TO GET THE ACTUAL NUMBER.)
                              END OF USER INPUT PROCESSING
     JOB TIME SUMMARY
       USER TIME (SEC)      =  0.40000
       SYSTEM TIME (SEC)    =  0.20000
       TOTAL CPU TIME (SEC) =  0.60000
       WALLCLOCK TIME (SEC) =          5
   Abaqus 6.14-1                                  Date 19-一月-2018   Time 10:56:56
        STEP    1  INCREMENT    1
        TIME COMPLETED IN THIS STEP   0.00
                        S T E P       1     S T A T I C   A N A L Y S I S
     AUTOMATIC TIME CONTROL WITH -
          A SUGGESTED INITIAL TIME INCREMENT OF                2.000E-02
          AND A TOTAL TIME PERIOD OF                           1.000E+03
          THE MINIMUM TIME INCREMENT ALLOWED IS                1.000E-05
          THE MAXIMUM TIME INCREMENT ALLOWED IS                 1.00
     LINEAR EQUATION SOLVER TYPE         DIRECT SPARSE
          UNSYMMETRIC MATRIX STORAGE AND SOLUTION WILL BE USED
msg文档和log文档见附件!
B.x
解决了吗
2023年3月17日
必亘心
如果UMAT中有write语句,也有可能是某条write语句引起的问题
2019年5月4日
影子_1236
depvar中没有定义状态变量的个数
2018年3月7日
