abaqus线性屈曲分析结果出现负的特征值代表什么?
一个简单的实体线性屈曲分析模型,施加的压力,结果在一阶和三阶出现负的特征值是什么意思?求出的临界载荷是反向的么?
全部回答 (3)
屈曲失稳只能在受压状态才能发生,说明你的结构在当前载荷状态下处于受拉状态,改变载荷方向,才可能失稳
2018年1月21日
特征值代表变形的方向与基本振型方向对称,不用纠结这个问题,只要看数值大小。
2018年1月20日
这是abaqus帮助里的,应该是最权威的解释了
Understanding negative eigenvalues
Sometimes, negative eigenvalues are reported in an eigenvalue buckling analysis. In most cases such negative eigenvalues indicate that the structure would buckle if the load were applied in the opposite direction. A classical example is a plate under shear loading; the plate will buckle at the same value for positive and negative applied shear load. Buckling under reverse loading can also occur in situations where it may not be expected. For example, a pressure vessel under external pressure may exhibit a negative eigenvalue (buckling under internal pressure) due to local buckling of a stiffener. Such “physical” negative buckling modes are usually readily understood once they are displayed and can usually be avoided by applying a preload before the buckling analysis.
Negative eigenvalues sometimes correspond to buckling modes that cannot be understood readily in terms of physical behavior, particularly if a preload is applied that causes significant geometric nonlinearity. In this case a geometrically nonlinear load-displacement analysis should be performed
