adams刚柔耦合仿真进行到一半,出错而终止,提示如下,为什么呢? 20
浏览:3344 回答:1
ERROR:   At time  2.443409871E-01 the integrator is unable to start/restart.  Possible Causes:
(1) The accuracy required for the numerical solution can not be attained.
Relax (increase) the value of the acceptable integration ERROR.
(2) Incompatible redundant constraints, a lock up, or a bifurcation
situation.  The latter two indicate a mechanism design problem.
(3) The system includes a zero (or relatively small) mass on a part with
an unconstrained translational degree of freedom.
Make sure you have mass on all parts with translational degrees of freedom.
(4) The system includes a zero (or relatively small) inertia on a part
with an unconstrained rotational degree of freedom.
Make sure you have inertias on all parts with rotational degrees of freedom.
(5) An Adams element has a function expression that equals exactly itself.
For example,
SFORCE/id1,I=id2,J=id3,ROT,FUNC=SFORCE(id1,jflag,comp,rm),and
DIFF/id4,IMPLICIT,IC=0,FUNC=DIF1(id4).
Similarly,
VARIABLE/id5, FUNC=VARVAL(id5)*TIME
equals itself at 1 second. Avoid setting an Adams element equal to itself.
ERROR:   Simulation failure detected.
是不是因为模型存在过约束?但是我检查了,没有过约束呀,还是我没发现?怎么检查模型的约束关系呢?请老师不吝赐教
郝逸凡
一般是工况对于模型来说太剧烈了,先用简单柔和的工况仿真下来检验模型是否有问题。
2018年5月2日
