在Optistruct里如何设定revolute joint?
浏览:1584 回答:6
目前在optistruct以简单模型设定revolute joint
并给予重力条件进行模拟,但结果会一直错误
错误为
** ERROR # 153 ***
 Exactly zero pivoting encountered during Numerical Factorization;
 the model may have rigid body mode.
  Solver error no. =   -503
        spc set id = 3
             index =      1
 Possible reasons are:
 1) insufficiently constrained model,
 2) having rigid body mechanisms within the model,
 3) extremely ill-conditioned rigid element sets,
 4) extremely thin shells (as used for skinning) that have MID2/MID3,
 5) gap elements with extremely high stiffness (KA, especially KT or MU).
 Check the model and rerun the problem.
 (MECHCHECK may be used to find the rigid body modes.  To do so,
  change the input to be an eigenvalue analysis and add MECHCHECK.)
 (WARNING: results obtained with MECHCHECK cannot be used because
          the model is changed internally.)
 This error was detected in subroutine bcsmtxfct.
目前在里面joint的设定为图所示
这边也想请教MPC和FE实际意义差在哪
目前都是已FE去进行设定
这边有附上模型(FE),有去找到有些文章是说这是约束不足
但有假设一些约束条件,这个错误还是会出现
在Optistruct里如何设定revolute joint?的图28.rar
LKZ
老师,这边有像你的截图方式一样打开.fem档去变更内容,但结果会有错误如下
*** ERROR 14: Missing      CID #    1 referenced by  JOINTG # 3187.
2018年2月26日
LKZ
1.rar
老师我这边有修改一个档案,只有单纯有revolute joint的文件,可以跑但不知道为什么现象非常奇怪,不知道能否麻烦老师您提点一下,非常感谢老师的回覆
2018年2月26日
TechmanLXS
这个revolute 类型的joint建立出来有点问题
你需要进fem文件进行手动编辑一下。
2018年2月26日
评论 3 点赞
