Logo 折叠
全网首发仿真工程师项目实训
下载app
返回旧版
首页 成长助手 小邻学院 社区 发现
职业认证 企业服务 行业会议
登录解锁更多功能
还没有账号?立即注册
技术邻
技术引领职场价值
电话
0571-86682823
商务合作
service@jishulink.com
  • 全部  > 
  • CAE仿真
使用cfx模拟出错,求教原因?
浏览: 3541 回答: 1
提示The ANSYS CFX solver exited with return code 1.   No results file has been created.求教什么原因
 ERROR #002100048 has occurred in subroutine SU_BNEXT.              |
 | Message:                                                           |
 | All vertices for a fluid domain lie on boundaries.  This is        |
 | considered to be a fatal error because control volume gradients    |
 | cannot be calculated, leading to serious discretization error.     |
 | A common cause for this error is a mesh which is only one          |
 | element thick, without symmetry or 1:1 periodicity on the lateral  |
 | boundaries.  If you have this situation, and the domain is         |
 | two-dimensional, please change the lateral boundary conditions     |
 | to symmetry or 1:1 periodicity.  Alternatively, for                |
 | three-dimensional simulations, please ensure that your mesh        |
 | has at least two elements across.                                  |
 | Execution is terminating.  This error message can be bypassed by   |
 | setting the expert parameter 'boundary vertex check = f', but      |
 | be aware that doing so may lead to sigificant solution error.
ANSYS 流体力学及仿真
全部回答 (1)
张哲 2018年3月6日
顶一下
2018年3月6日
相似问题
查看全部
  • 提交inp文件报错,求大佬解释一下!!谢谢!!!? 6个回答
    Error in job bcs-1: in keyword *BOUNDARY, file "bcs_1.inp", line 8440: Unknown assembly node set BOTTOM Error in job bcs-1: in keyword *BOUNDARY, file "bcs_1.inp", line 8453: Unknown assembly node set
  • 求大神,ABAQUS,边界条件不活跃,肿么办呐? 13个回答
    做磨粒切削仿真时 The job input file "Steady_cutting.inp" has been submitted for analysis. Error in job Steady_cutting: A BOUNDARY CONDITION HAS BEEN SPECIFIED ON NODE SET ASSEMBLY_REF_GEO BUT THIS NODE SET IS
  • abaqus边界条件施加的问题 1个回答
    刚自学abaqus,要对模型进行显式动力学分析,想施加一个半正弦加速度载荷,但是分析总是出错 想问一下大家是不是加速度载荷和固定约束冲突了,因为加速度载荷我是加在整个模型上的,不知道怎样解决 ***ERROR: THIS DEGREE OF FREEDOM HAS BOTH DISPLACEMENT AND ACCELERATION SPECIFIED. THIS IS NOT ALLOWED.
推荐阅读
手把手教你ABAQUS耗能钢节点建模与分析
1点 1点
¥169
前沿技术!大数据分析及人工智能在优化软件中的应用
IDAJ中国 IDAJ中国
¥9.99
新一代智能头灯的动态设计评估与仿真
新一代智能头灯的动态设计评估与仿真
Ansys中国 Ansys中国
免费
UG有限元基础教程
UG有限元基础教程
moonshine🤓 moonshine🤓
免费
0#块箱梁托架法施工结构模拟
0#块箱梁托架法施工结构模拟
yudachuan1105 yudachuan1105
¥200
一线科技工作者接受仿真咨询服务的全过程经验分享
技术邻直播 技术邻直播
免费
UG培训第九课:自由曲面构造法
UG培训第九课:自由曲面构造法
luffy8610 luffy8610
¥20
abaqus座椅滚轮拉脱力强度分析
abaqus座椅滚轮拉脱力强度分析
任总 任总
¥90
