abaqus耦合运动问题请教? 100
浏览:1529 回答:8
abaqus耦合运动在模态计算中出现错误,Three factorizations in a row failed. Check the model. It is possible that the model contains the kinematic coupling definition set up in a way that a degree of freedom has neither mass nor stiffness.
请教大神怎么解决
