利用abaqus模拟螺栓连接,施加螺栓载荷
浏览:3072 回答:2
202 nodes may not be used with a multi-point constraint since they are also part of pretension section. The nodes have been identified in node set ErrNodeMPCPretenSec.
做的时候总是报这个错,我是在螺栓的横截面上施加的螺栓载荷,然后这个错误也是出现在这个横截面上,这个该怎么解决啊!!
