ls-dyna模拟时出现Warning 302 (KEY+302),请问怎么解决?
浏览:1793 回答:2
求助  时勇党《基于ansys8.1进行显示动力学分析》一书中,炸药在土体中爆破的例子,根据书中的方法得到的K文件   计算时出现的是这样一串提示
*** Warning 10302 (KEY+302)
     CHECKING MATERIAL INPUT Part ID= 1
     The default hourglass properties of the following
     ALE part are being modified to avoid unnecessary
     application of hourglass forces.
     Resetting coefficient qm=1.0e-6.
     PART ID 1 with
     MATERIAL ID 1 and
     EOS ID 0
     This is PART 1 in the order of input.
     CHECKING MATERIAL INPUT Part ID= 2
     PART ID 2 with
     MATERIAL ID 2 and
     EOS ID 1
     This is PART 2 in the order of input.
     CHECKING MATERIAL INPUT Part ID= 3
     PART ID 3 with
     MATERIAL ID 3 and
     EOS ID 3
     This is PART 3 in the order of input.
后面为K文件部分内容:
$                             SECTION DEFINITIONS                              $
*SECTION_SOLID_ALE
         1        11
$                             MATERIAL DEFINITIONS                             $
*MAT_SOIL_AND_FOAM
         1      1.80 1.601E-04 1.328E+02 3.300E-03 1.310E-07    0.1232       0.0
       0.0       0.0
       0.0     0.050     0.090      0.11      0.15      0.19      0.21      0.22
      0.25      0.30
       0.0 3.420E-02 4.530E-02 6.760E-02 1.270E-01 2.080E-01 2.710E-01 3.920E-01
 5.660E-01 1.230E+00
*MAT_HIGH_EXPLOSIVE_BURN
         2 1.6400000 0.6930000 0.2700000 0.0000000 0.0000000 0.0000000 0.0000000
*EOS_JWL
         1 3.7400000 3.2300e-2 4.1500001 0.9500000 0.3000000 0.0700000 1.0000000
*INITIAL_DETONATION
         2       2.5       2.5        80      0.00
*MAT_NULL
         3 1.290E-03 0.0000000 0.0000000 0.0000000 0.0000000 0.0000000 0.0000000
*EOS_LINEAR_POLYNOMIAL
         3 -1.00E-06 0.0000000 0.0000000 0.0000000 0.4000000 0.4000000 0.0000000
 2.500E-06 1.0000000
$                              PARTS DEFINITIONS                               $
*PART
Part          1 for Mat         1 and Elem Type         1
         1         1         1         0         0         0         0
*PART
Part          2 for Mat         2 and Elem Type         1
         2         1         2         1         0         0         0
*PART
Part          3 for Mat         3 and Elem Type         1
         3         1         3         3         0         0         0
*ALE_MULTI-MATERIAL_GROUP
        1          1
        2          1
        3          1
小生有空
这个不用解决,只是你采用section_solid_ale产生的警告,不是error
2018年5月21日
