vumat子程序计算出错,求解答? 130
浏览:1113 回答:2
vumat求解时出现了如下错误,不知道问题出在哪里,请问有知道的吗?
The executable explicit.exe aborted with system error code 1073741819. Please check the .dat, .msg, and .sta files for error messages if the files exist.  If there are no error messages and you cannot resolve the problem, please run the command "abaqus job=support information=support" to report and save your system information.  Use the same command to run Abaqus that you used when the problem occurred.  Please contact your local Abaqus support office and send them the input file, the file support.log which you just created, the executable name, and the error code.
星辰_北极星
按照提示,到.dat, .msg, and .sta文件还有log文件中找错误,一般给的信息都比较全,最可能是dat和log文件中。
2018年6月3日
