abaqus接触分析例子出错?
浏览:1134 回答:3
书上的例子,一直出错.
The executable standard.exe aborted with system error code 1073741819. Please check the .dat, .msg, and .sta files for error messages if the files exist.  If there are no error messages and you cannot resolve the problem, please run the command "abaqus job=support information=support" to report and save your system information.  Use the same command to run Abaqus that you used when the problem occurred.  Please contact your local Abaqus support office and send them the input file, the file support.log which you just created, the executable name, and the error code.
哈哈静
这个例子是哪本书上的?
2018年6月6日
米粉
把文件mkl_avx2.dll改名为mkl_avx2.dll.11.0.0.1 11对应的是版本
2018年5月26日
