fluent UDF好像没有抓取到最大温度,请帮忙指正? 50
浏览:1171 回答:6
程序是想抓取一个域内体网格的最大温度tmax,然后用tmax和设定的温度313.15比较大小,然后来判定执行哪个加热功率,但是程序一直执行define profile语句中else的功率,虽然tmax已经大于我设定的313.15。实在看不出哪里有错,还请各位大神帮忙指点一下,感谢!感谢!
程序如下:
#include "udf.h" real tmax; real thermosensor_temperature; real heat_change_temperature = 313.15; /*40 du*/ real heater_change = 26400000; /*100W*/ real heater_unchange = 79600000;/*300W*/ DEFINE_EXECUTE_AT_END(tsensor) { cell_t c; Domain *d; Thread *t; d = Get_Domain(1); t = Lookup_Thread(d,6); tmax=253.15; /*-20du*/ begin_c_loop(c,t) { thermosensor_temperature = C_T(c,t); /* get thermocouple temperature */ if(thermosensor_temperature > tmax) { tmax = thermosensor_temperature; } else { tmax=253.15;/*-20du*/ } } end_c_loop(c,t) } DEFINE_PROFILE(heat_bc,t,i) { face_t f; if (tmax >= heat_change_temperature) { begin_f_loop(f,t) { F_PROFILE(f,t,i) = heater_change; /*Message("The heater_change is '%f'\n", heater_change);*/ } end_f_loop(f,t) } else { begin_f_loop(f,t) { F_PROFILE(f,t,i) = heater_unchange; /*Message("The heater_unchange is '%f'\n", heater_unchange);*/ } end_f_loop(f,t) } }
