顶部banner
Logo 折叠
全网首发仿真工程师项目实训
下载app
返回旧版
首页 成长助手 小邻学院 社区 发现
职业认证 企业服务 行业会议
登录解锁更多功能
还没有账号?立即注册
技术邻
技术引领职场价值
电话
0571-86682823
商务合作
service@jishulink.com
  • 全部  > 
  • CAE仿真
ansys命令流error求解? 20
浏览: 2135 回答: 2
壳模型周围均布三向弹簧约束,求解总是出现 *** WARNING *** CP = 5.148 TIME= 11:15:35 Input time should be greater than zero. *** ERROR *** CP = 5.647 TIME= 11:15:35 The displacements input as real constants must be in ascending order for element 1937. *** ERROR *** CP = 5.647 TIME= 11:15:35 The displacements input as real constants must be in ascending order for element 961. *** ERROR *** CP = 5.647 TIME= 11:15:35 The last input displacement for element 1937 must be positive. 求解答!以下是命令流: /prep7 et,1,shell63 r,1,0.016,0.016,0.016,0.016,,,,, et,2,combin39 keyopt,2,3,1 et,3,combin39 keyopt,3,3,2 et,4,combin39 keyopt,4,3,3 et,5,combin39 keyopt,5,3,3 r,2,-5*e-3,-5*e4,-1.5*e-3,-5*e4,0,0!定义横向弹簧本构 rmore,1.5*e-3,5*e4,5*e-3,5*e4 r,3,-5*e-3,-5*e4,-1.5*e-3,-5*e4,0,0!定义轴向弹簧本构 rmore,1.5*e-3,5*e4,5*e-3,5*e4 r,4,-4*e-3,-6.9*e4,-2.5*e-3,-6.9*e4,0,0!定义垂直弹簧本构 rmore,1.5*e-3,1.667*e4,5*e-3,1.667*e4 r,5,0,0,0.05,600000,0.3,1.4*e6!定义等效弹簧本构 mp,ex,1,2.1e11 mp,prxy,1,0.3 mp,dens,1,7800 k,1 k,2,0,0,30 l,1,2 circle,1,0.5 adrag,2,3,4,5,,,1 lsel,r,loc,z,0 lesize,all,,,4 lsel,s,length,,30 lesize,all,,,60 mshape,0,2d mshkey,1 amesh,all NGEN,2,1000,all, , , , , ,1, TYPE, 2 MAT, 1 REAL, 2 ESYS, 0 SECNUM, TSHAP,LINE EINTF,0.0001, ,LOW,0,0,0,0,0 TYPE,3 MAT, 1 REAL,3 ESYS, 0 SECNUM, TSHAP,LINE EINTF,0.0001, ,LOW,0,0,0,0,0 TYPE,4 MAT, 1 REAL,4 ESYS,0 SECNUM, TSHAP,LINE EINTF,0.0001, ,LOW,0,0,0,0,0 alls !两端弹簧 NSEL,S,LOC,Z,0 NSEL,A,LOC,Z,30 TYPE, 5 MAT,1 REAL, 5 ESYS, 0 SECNUM, TSHAP,LINE EINTF,0.0001, ,LOW,0,0,0,0,0 alls NSEL,S, , ,1001,1976,1 D,all,all nsel,s,loc,z,0 NSEL,A,LOC,Z,30 nsel,r,,,1,1000 d,all,ux,,,,,uy,roty,rotz alls /solu antype,trans alphad, betad, timint,off nlgeom,on time,1*e-6 nsubst,4 kbc,1 acel,0,-9.8 solve
ANSYS 结构CAE
全部回答 (1)
邹正刚 2018年6月15日
  是你对 combin39 单元定义的实常数有问题。按照帮助文件,该实常数是 位移-力 曲线,其中的位移应该是升序排列的,而你的实常数定义,比如:
    r,2,-5*e-3,-5*e4,-1.5*e-3,-5*e4,0,0  !定义横向弹簧本构
  其中的实数的格式不符合要求,比如:
    -5*e-3, -1.5*e-3, ,0
  前两个实数中间多了一个 * 号,应该改为:
    -5e-3,  -1.5e-3
  类似的实数都需要修改,包括:
    time,1*e-6
  需要改为:
    time,1e-6
  按照原来的命令流,生成的模型中实常数 2 如下:
  显然是错误的。
  修改后的命令流如下:
  ! 以下是修改后的命令流:
 fini
 /clear
 /filn,3D_springs,1
 /prep7
 et,1,shell63
 et,2,combin39
 keyopt,2,3,1
 et,3,combin39
 keyopt,3,3,2
 et,4,combin39
 keyopt,4,3,3
 et,5,combin39
 keyopt,5,3,3
 r,2,-5e-3,-5e4,-1.5e-3,-5e4,0,0  !定义横向弹簧本构
 rmore,1.5e-3,5e4,5e-3,5e4
 r,3,-5e-3,-5e4,-1.5e-3,-5e4,0,0  !定义轴向弹簧本构
 r,4,-4e-3,-6.9e4,-2.5e-3,-6.9e4,0,0    !定义垂直弹簧本构
 rmore,1.5e-3,1.667e4,5e-3,1.667e4
 r,5,0,0,0.05,600000,0.3,1.4e6!  定义等效弹簧本构
 mp,ex,1,2.1e11
 mp,prxy,1,0.3
 mp,dens,1,7800
 k,1
 k,2,0,0,30
 l,1,2
 circle,1,0.5
 adrag,2,3,4,5,,,1
 lsel,r,loc,z,0
 lesize,all,,,4
 lsel,s,length,,30
 lesize,all,,,60
 mshape,0,2d
 mshkey,1
 amesh,all
 TYPE, 2
 MAT, 1
 REAL, 2
 ESYS, 0
 SECNUM,
 TSHAP,LINE
 TYPE,3
 MAT, 1
 REAL,3
 ESYS, 0
 SECNUM,
 TSHAP,LINE
 TYPE,4
 MAT, 1
 REAL,4
 ESYS,0
 SECNUM,
 TSHAP,LINE
 alls !两端弹簧
 NSEL,S,LOC,Z,0
 NSEL,A,LOC,Z,30
 TYPE, 5
 MAT,1
 REAL, 5
 ESYS, 0
 SECNUM,
 TSHAP,LINE
 alls
 D,all,all
 nsel,s,loc,z,0
 NSEL,A,LOC,Z,30
 nsel,r,,,1,1000
 alls
 /solu
 antype,trans
 alphad,
 betad,
 timint,off
 nlgeom,on
 time,1e-6          !  原为  1*e-6, 被当作 -6
 nsubst,4,10,2      !  原为  nsubst,4
 kbc,1
 acel,0,-9.8
 solve
2018年6月15日
已采纳 评论 1 点赞 1
相似问题
查看全部
  • ansys 动力时程分析收敛问题? 暂无回答
    做管线的动力时程分析,建模完成后进行瞬态分析显示没问题,但当加地震波之后不收敛,请大神帮忙看看什么问题,命令流如下,地震波文件见附件 /prep7 et,1,shell63 r,1,0.016,0.016,0.016,0.016,,,,, et,2,combin39 keyopt,2,3,1 et,3,combin39 keyopt,3,3,2 et,4,combin39 keyopt,4,3,3
  • 埋地管道动力时程分析没有问题和警告,但应力应变结果很小,位移基本没有怎么回事? 暂无回答
    埋地管道动力时程分析没有问题和警告,计算结果位移非常小,应力也很小,感觉不太对,我用的是m,pa为单位,有大神能帮忙检查下,看是什么问题不,非常感谢,以下是完整的命令流,附件为地震数据文件。 /prep7 et,1,shell63 r,1,0.016,0.016,0.016,0.016,,,,, et,2,combin39 keyopt,2,3,1 et,3,combin39 keyopt,3,3
  • ANSYS接触滑移分析遇到该错误,求大神指点? 1个回答
    鄙人是菜鸡,用的命令流和GUI交互操作,具体操作指令来自.log文件,请大神见谅, 出现错误如下: The L-2 norm of the residual force overflowed. This may be caused by PRED,ON or birth/dead elements. Please use PRED,OFF and try again. .log中的具体命令为 /P
推荐阅读
转子旋转的周期性模型-水冷电机散热仿真
转子旋转的周期性模型-水冷电机散热仿真
技术邻小李 技术邻小李
¥100
ABAQUS热切割数值模拟
ABAQUS热切割数值模拟
hitliuyong hitliuyong
¥99
Altair SimSolid 求解精度控制和对标网络研讨会
ALTAIR ALTAIR
免费
Altair基于仿真驱动的制造工艺解决方案
ALTAIR ALTAIR
免费
HBK声学测量基础
HBK声学测量基础
HBK声学与振动 HBK声学与振动
免费
Mathcad基本操作
Mathcad基本操作
HYT HYT
¥89
后排座椅和安全带固定点强度分析
后排座椅和安全带固定点强度分析
Crisby_Vectory_TrHo Crisby_Vectory_TrHo
¥80
workbench纯六面体网格划分
workbench纯六面体网格划分
八号楼停水 八号楼停水
¥100
BOX-3D变宽斜钢箱梁绘图及功能更新演示
敦樸DUNPU 敦樸DUNPU
免费
新四化浪潮下,传统汽车人如何积极转型
新四化浪潮下,传统汽车人如何积极转型
夸克 夸克
免费
Cadence Fidelity 水泵水轮机CFD模拟解决方案和应用
Cadence楷登 Cadence楷登
免费
abaqus_python提取odb中的最大值结果3
tanquery tanquery
免费
ANSYS新版本功能速递: HFSS微放电仿真
Ansys中国 Ansys中国
免费
0#块箱梁托架法施工结构模拟
0#块箱梁托架法施工结构模拟
yudachuan1105 yudachuan1105
¥200
基于Hypermesh与ABAQUS联合仿真的摄像头模组跌落分析——工作创建以及检查
北鲲 北鲲
¥99
ABAQUS钢管混凝土柱温度场及耐火性能分析(未完)
地下结构设计
¥40
5G终端天线仿真设计方法及其应用
5G终端天线仿真设计方法及其应用
Ansys中国 Ansys中国
免费
abaqus三维切削数值模拟(sph法)
abaquser abaquser
¥30
Python面向对象的有限元编程
Python面向对象的有限元编程
weilai00 weilai00
¥60
基于ABAQUS和ANSYS接触分析
基于ABAQUS和ANSYS接触分析
宁博士CAE团队 宁博士CAE团队
免费
