ABAQUS调用VUMAT子程序运行了一部分后出现代码1073741819错误,是什么原因? 63
浏览:2125 回答:4
The executable explicit.exe aborted with system error code 1073741819. Please check the .dat, .msg, and .sta files for error messages if the files exist. If there are no error messages and you cannot resolve the problem, please run the command "abaqus job=support information=support" to report and save your system information. Use the same command to run Abaqus that you used when the problem occurred. Please contact your local Abaqus support office and send them the input file, the file support.log which you just created, the executable name, and the error code.
请问这是什么原因造成的?为什么能算一部分,就终止了
