workbench画好的网格导入fluent检查之后失败的问题怎么解决?
浏览:1752 回答:2
Checking mesh........................
WARNING: Unassigned interface zone detected for interface 9...
Done.
WARNING: Mesh check failed.
To get more detailed information about the mesh check failure
increase the mesh check verbosity via the TUI command
/mesh/check-verbosity.
求助这个问题应该怎么解决呢?我是刚接触,照着别人的一步步来,结果出现这样的问题,我是一点都不懂,请各位高手教一下
