ABAQUS分析中断,遇到这样的问题怎么办?
浏览:1327 回答:2
The executable standard.exe aborted with system error code 529697949. Please check the .dat, .msg, and .sta files for error messages if the files exist. If there are no error messages and you cannot resolve the problem, please run the command "abaqus job=support information=support" to report and save your system information. Use the same command to run Abaqus that you used when the problem occurred. Please contact your local Abaqus support office and send them the input file, the file support.log which you just created, the executable name, and the error code.
大佬求指教
