abaqus中定义b31梁单元,出现的错误?
浏览:1734 回答:2
Error in defining or computing beam section normal in 1 element. The elements have been identified in element set ErrElemBeamSecNormal. The beam cross-section direction vectors coincide at a node in 1 element. 请问该如何解决呢?
yunduan082
梁单元方向定义有问题
2018年7月13日
