按照庄茁的《基于abaqus的有限元分析与应用》一步一步坐,老是弹出下列错误,请各位帮在下分析为何?
浏览:1313 回答:1
The executable package.exe aborted with system error code 1073741511. Please check the .dat, .msg, and .sta files for error messages if the files exist. If there are no error messages and you cannot resolve the problem, please run the command "abaqus job=support information=support" to report and save your system information. Use the same command to run Abaqus that you used when the problem occurred. Please contact your local Abaqus support office and send them the input file, the file support.log which you just created, the executable name, and the error code.
