顶部banner
Logo 折叠
全网首发仿真工程师项目实训
下载app
返回旧版
首页 成长助手 小邻学院 社区 发现
职业认证 企业服务 行业会议
登录解锁更多功能
还没有账号?立即注册
技术邻
技术引领职场价值
电话
0571-86682823
商务合作
service@jishulink.com
  • 全部  > 
  • CAE仿真
Abaqus方向的问题? 99
浏览: 2493 回答: 1
Local tangent directions on surfaces in space
Local tangent directions are needed on surfaces in space; for example, to provide a convention for describing components of slip on an element-based contact surface or components of stress and strain in a shell. The convention used in Abaqus for such directions is as follows.
The default local 1-direction is the projection of the global x-axis onto the surface. If the global x-axis is within 0.1° of being normal to the surface, the local 1-direction is the projection of the global z-axis onto the surface. The local 2-direction is then at right angles to the local 1-direction, so that the local 1-direction, local 2-direction, and the positive normal to the surface form a right-handed set (see Figure 1.2.2–1). The positive normal direction is defined in an element by the right-hand rotation rule going around the nodes of the element. The local surface directions can be redefined; see “Orientations,” Section 2.2.5.
这句话 if the global x-axis is within 0.1° of being normal to the surface, the local 1-direction is the projection of the global z-axis onto the surface.是什么意思
ABAQUS
全部回答 (1)
寒江雪_123 2018年8月7日
就是如果整体坐标系的x轴与面单元垂直,单元局部1轴就采用整体z轴在面上的投影。
2018年8月7日
评论 点赞 1
相似问题
查看全部
  • abaqus复合材料连续壳指派截面报错? 5个回答
    Error in job Job-2022-18: The local-1 direction (after the additional rotation and permutation) of the material orientation , specified via *ORIENTATION, is normal to the SHELL, MEMBRANE, GASKET, COHE
  • ABAQUS复合材料建模弹性常数G13,G23可以设置为0吗? 5个回答
    我使用ABAQUS建一个复合材料层合板进行线性屈曲分析,使用的是壳单元(S4R),但是我只有四个弹性常数E11,E22,ν12,G12,我把G13和G23设置为0之后计算显示计算出错,这个怎么解决呢?我在网上搜了下有人说厚度方向(3方向)相对于其他两个方向尺寸可以忽略,所以可近似认为σ33=0,τ13=τ23=0,即平面应力状态,可以用E1,E2,ν12,G12四个独立弹性常数来描述平面应力状态下
  • abaqus子程序dflux在调用程序时出现越界访问错误 1个回答
    我是用abaqus子程序dlux施加在圆柱外表面热流密度表达式关于cos余弦函数,以下是子程序的代码,提示 ABAQUS/standard rank 0 encountered a SEGMENTATION FAULT ERROR CATEGORY: ELEMENT LOOP是什么原因,应该怎么改 SUBROUTINE DFLUX(FLUX, SOL, KSTEP, KINC, TIME, NOE
推荐阅读
转子旋转的周期性模型-水冷电机散热仿真
转子旋转的周期性模型-水冷电机散热仿真
技术邻小李 技术邻小李
¥100
ABAQUS热切割数值模拟
ABAQUS热切割数值模拟
hitliuyong hitliuyong
¥99
Altair SimSolid 求解精度控制和对标网络研讨会
ALTAIR ALTAIR
免费
Altair基于仿真驱动的制造工艺解决方案
ALTAIR ALTAIR
免费
HBK声学测量基础
HBK声学测量基础
HBK声学与振动 HBK声学与振动
免费
Mathcad基本操作
Mathcad基本操作
HYT HYT
¥89
后排座椅和安全带固定点强度分析
后排座椅和安全带固定点强度分析
Crisby_Vectory_TrHo Crisby_Vectory_TrHo
¥80
workbench纯六面体网格划分
workbench纯六面体网格划分
八号楼停水 八号楼停水
¥100
BOX-3D变宽斜钢箱梁绘图及功能更新演示
敦樸DUNPU 敦樸DUNPU
免费
新四化浪潮下,传统汽车人如何积极转型
新四化浪潮下,传统汽车人如何积极转型
夸克 夸克
免费
Cadence Fidelity 水泵水轮机CFD模拟解决方案和应用
Cadence楷登 Cadence楷登
免费
abaqus_python提取odb中的最大值结果3
tanquery tanquery
免费
十一特惠--Adams Car 模型建立的相关硬点及运动副
仿真分析 仿真分析
¥9.9
ANSYS新版本功能速递: HFSS微放电仿真
Ansys中国 Ansys中国
免费
0#块箱梁托架法施工结构模拟
0#块箱梁托架法施工结构模拟
yudachuan1105 yudachuan1105
¥200
基于Hypermesh与ABAQUS联合仿真的摄像头模组跌落分析——工作创建以及检查
北鲲 北鲲
¥99
ABAQUS钢管混凝土柱温度场及耐火性能分析(未完)
地下结构设计
¥40
5G终端天线仿真设计方法及其应用
5G终端天线仿真设计方法及其应用
Ansys中国 Ansys中国
免费
abaqus三维切削数值模拟(sph法)
abaquser abaquser
¥30
Python面向对象的有限元编程
Python面向对象的有限元编程
weilai00 weilai00
¥60
