comsol安装出现错误求助?
浏览:1126
点击setup后出现错误,log file文件描述如下:
!SESSION 2018-08-13 09:17:22.798 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.8.0_112
java.vendor=Oracle Corporation
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=zh_CN
Framework arguments:  install -Dcs.installroot=I:
Command-line arguments:  -os win32 -ws win32 -arch x86_64 install -Dcs.installroot=I:
!ENTRY org.eclipse.osgi 4 0 2018-08-13 09:17:23.278
!MESSAGE Application error
!STACK 1
java.lang.IllegalStateException: Unable to acquire application service. Ensure that the org.eclipse.core.runtime bundle is resolved and started (see config.ini).
        at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:78)
        at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
        at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
        at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
        at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
        at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
        at java.lang.reflect.Method.invoke(Method.java:498)
        at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:669)
        at org.eclipse.equinox.launcher.Main.basicRun(Main.java:608)
        at org.eclipse.equinox.launcher.Main.run(Main.java:1515)
