求问,workbench响应面优化出错?
浏览:2195
错误1:Update failed for the Design of Experiments component in Response Surface Optimization. 4 Design Points failed to update and have been preserved in the project. From the Project Schematic, edit the Parameter Set cell to attempt a single Design Point update and review the detailed error messages.
错误2:The Model component in XXX(项目名称) for Design Point 14 requires user input before it can be updated. For instructions on how to address the cell in its current state, click the blue triangle in the lower right corner of the cell.
求问,workbench响应面优化出错?的图1
这是DOE算出来的结果
所有设计点都是闪电加右边红色的叉,算不出来,求大神解答
