abaqus作业提交问题,求大神解答? 20
浏览:1377 回答:2
边尺寸设为5时能成功运行,再细分为4时就会出现如下错误: Job Job-6: Analysis Input File Processor completed successfully. Job Job-6: Abaqus/Explicit Packager completed successfully. ERROR in job messaging system: Error in connection to . Please contact your local Abaqus support office and send them the input file, the file support.log which you just created, the executable name, and the error code. Job Job-6 aborted due to errors.
每天进步一点点
改一个工作目录试一下。
2018年8月21日
已采纳 评论 1 点赞
