ANSYS模态分析后会闪退
浏览:2246 回答:1
用ANSYS建立了一个简支梁模型,做完模态分析已经有solution is done了,但是紧接着就出现错误:
An unexpected error ( SIG$SEGV ) has occurred...  ANSYS internal data
 has been corrupted.  ANSYS is unable to recover and will terminate.
 Previously saved files are unaffected.  Please send the data leading
 to this operation to your technical support provider, as this will
 allow ANSYS, Inc to improve the program.
然后软件就自己退出了。而且我如果不做模态分析单做瞬态分析或静力分析都能算,就模态分析不行,有人知道问题出现在哪吗~急
邹正刚
  似乎是你的软件出问题了。
2018年8月26日
