abaqus做流固耦合仿真出现以下问题,请问应该如何解决? 20
浏览:1507 回答:1
abaqus做流固耦合仿真出现以下问题,请问应该如何解决?的图1abaqus做流固耦合仿真出现以下问题,请问应该如何解决?的图2Error in job Co-execution-1-solid: Due to this co-simulation Failure Abaqus cannot continue.
Job Co-execution-1-solid: Abaqus/Standard aborted due to errors.
Error in job Co-execution-1-solid: Abaqus/Standard Analysis exited with an error - Please see the message file for possible error messages if the file exists. Job Co-execution-1-solid aborted due to errors. ERROR in job messaging system: Error in connection to analysis Error in job Co-execution-1-fluid: The executable SMACfdMain.exe aborted with system error code 3. Please check the .dat, .msg, and .sta files for error messages if the files exist. If there are no error messages and you cannot resolve the problem, please run the command "abaqus job=support information=support" to report and save your system information. Use the same command to run Abaqus that you used when the problem occurred. Please contact your local Abaqus support office and send them the input file, the file support.log which you just created, the executable name, and the error code. Job Co-execution-1-fluid aborted due to errors.
Kevin_3249
我做ABAQUS cfd耦合热传导也碰到了,应该是电脑运作内存不足或者文件输出不稳定导致的,已经解决了。可以从以下几个方法去尝试一下: 1⃣️ 并行计算使用默认的,不勾选多核计算 2⃣️使用管理员运行ABAQUS 3⃣️job里面不要修改内存使用设置 4⃣️使用虚拟内存 5️⃣ job里面的暂存文件选择一个有大一些空间的盘里面的文件夹,注意路径是英文
2024年4月21日
