abaqus 2018关联子程序出错误? 200
浏览:1422 回答:2
Analysis initiated from SIMULIA established products
Abaqus JOB std_user
Abaqus 3DEXPERIENCE R2018x
Abaqus License Manager checked out the following licenses:
Abaqus/Standard checked out 5 tokens from Flexnet server localhost.
<1019 out of 1024 licenses remain available>.
Begin Compiling Abaqus/Standard User Subroutines
9/7/2018 7:22:47 PM
Intel(R) Visual Fortran Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 14.0.1.139 Build 20131008
Copyright (C) 1985-2013 Intel Corporation.  All rights reserved.
End Compiling Abaqus/Standard User Subroutines
Begin Linking Abaqus/Standard User Subroutines
LINK : fatal error LNK1181: cannot open input file 'vcruntime.lib'
Abaqus Error: Problem during linking - Abaqus/Standard User Subroutines.
  This error may be due to a mismatch in the Abaqus user subroutine arguments.
  These arguments sometimes change from release to release, so user subroutines
  used with a previous release of Abaqus may need to be adjusted.
Begin Convert MFS to SFS
9/7/2018 7:22:51 PM
Run SMASimUtility.exe
9/7/2018 7:22:51 PM
End Convert MFS to SFS
Abaqus/Analysis exited with errors
总是提示这个错误,有哪位大神帮忙看看,不胜感激
蓝牙
经验,按照网上教程关联不上的多出在vs的版本和fortran的版本上!上图是个关联对应图供参考
2018年9月9日
评论 点赞 2
蓝牙
2018年9月9日
评论 点赞 2
