OptiStruct模态分析报错,什么原因啊? 50
浏览:2212 回答:3
 *** ERROR # 160 ***
 Gram-Schmidt reorthogonalization did not converge.  This is caused by
 ill-conditioning of the shifted matrix in Lanczos run.
 (e.g. zero lower bound specified for a model with rigid body modes.)
  Solver error no. =    728
        subcase id =      1
 This error was detected in subroutine splncz4.
 This error occurs in module "eigdrv".
RESOURCE USAGE INFORMATION
 MAXIMUM MEMORY USED                                     13772 MB
 MAXIMUM DISK SPACE USED                                 18830 MB
COMPUTE TIME INFORMATION
 EXECUTION STARTED                         Tue Sep 11 20:02:34 2018
 EXECUTION COMPLETED                       Tue Sep 11 20:34:30 2018
 ELAPSED TIME                                         00:31:56
 CPU TIME                                             00:12:04
 *** PROGRAM STOPPED: FATAL ERROR(s) ENCOUNTERED.
                        ***** END OF REPORT *****
 For Useful OptiStruct Tips and Tricks, go to the URL:
 http://www.altairhyperworks.com/tips.aspx
 OptiStruct error termination report printed to file
 "biw_modes.stat".
 PROGRAM STOPPED DUE TO ERROR.
 A fatal error has occurred during computations:
  *** ERROR # 160 ***
         subcase id =      1
L_2785
解决了吗
2023年12月1日
L_2785
解决了吗
2023年12月1日
熊猫
看下你的EIGRL的设置,感觉这里的问题
2018年9月12日
