ABAQUS中cavity radiation分析的输出变量HFL与RADFL的区别是什么? 100
浏览:2038
HFL:Heat flux per unit area leaving the slave surface.
RADFL:Radiation flux per unit area.
哪一个变量代表低温物体表面受到的热辐射通量
