Abaqus提交作业后经常被SIGTERM打断? 20
浏览:1569
问题一:提交作业后算到一半或者还没算经常报错Process terminated by external request (SIGTERM or SIGINT received). 问题二:新电脑两个处理器,一个36线程,两个72线程,提交作业计算时只能用36个,另外36个用不了,警告:The number of cpus (70) exceeds the number of cpus available (36). Please make sure to define the mp_host_list Abaqus environment variable for DMP runs. 哪个大神知道是什么问题,卸载重装了好几个版本的Abaqus了,都不行
