abaqus优化模块遇到这种问题怎么解决?
浏览:2572
 **** ERROR in Tosca for Abaqus - module "FE-solver : abaqus" ****
  Error occured during Analysis.
  The following string could NOT be found in the solver output file
  String : "THE ANALYSIS HAS BEEN COMPLETED"
  File   : "m32655941516123513-Job.msg"
  Please check the ERROR log files of the solver
  for further information.
 Logfile: m32655941516123513\TOSCA.OUT
  Error occured during optimization in "FE-solver : abaqus"
  Module call: "D:\ABAQUS\6.14-1\code\bin\abq6141.exe" job=m32655941516123513-Job analysis interactive message messaging_mechanism=DIRECT listener_name=RZA64BPSHZUMX83 listener_resource=3328 direct_port=49262 memory=90%
  Return code: 1
  Please check the corresponding ERROR log Files
Optimization process failed with an error.
