abaqus计算出现错误,原因在于结果文件输出了太多单元的塑性应变数据,怎么解决?
浏览:1431 回答:4
The executable package.exe aborted with system error code 529697949.Please check the .dat, .msg, and .sta files for error messages if the files exist. If there are no error messages and you cannot resolve the problem, please run the command "abaqus job=support information=support" to report and save your system information. Use the same command to run Abaqus that you used when the problem occurred. Please contact your local Abaqus support office and send them the input file, the file support.log which you just created, the executable name, and the error code.
计划输出30万到150万网格单元的塑性应变信息
