abaqus做一个简单的预制裂纹微积分计算的时候出现网格问题?调整好多天了,调整不好?
浏览:2268 回答:2
作业输入文件 "Job-1.inp" 已提交分析.
Error in job Job-1: Triangles, Tetrahedra and wedges may not be used in a contour integral region. 273 elements are within a contour region. The elements are identified in element set ErrElemIncorrContInteg.
Job Job-1: Analysis Input File Processor aborted due to errors.
Error in job Job-1: Analysis Input File Processor exited with an error.
Job Job-1 aborted due to errors.
Wind12306
试试XFEM做做看。
2018年11月22日
