TOSCA安装后无法使用?
浏览:1227
(ERROR   ) [09:47:25|SMATsoToscaPrep]  Failed to request necessary licenses from licensing system
(ERROR   ) [09:47:25|SMATsoToscaPrep]   System answered: Checkout failed for license feature tosca_topo
(ERROR   ) [09:47:25|SMATsoToscaPrep] FlexLM reports: Invalid (inconsistent) license key.
(ERROR   ) [09:47:25|SMATsoToscaPrep]  The license key and data for the feature do not match.
(ERROR   ) [09:47:25|SMATsoToscaPrep]  This usually happens when a license file has been altered.
(ERROR   ) [09:47:25|SMATsoToscaPrep] Feature:       tosca_topo
(ERROR   ) [09:47:25|SMATsoToscaPrep] License path:  27011@Server;
(ERROR   ) [09:47:25|SMATsoToscaPrep] FLEXnet Licensing error:-8,544
(ERROR   ) [09:47:25|SMATsoToscaPrep] For further information, refer to the FLEXnet Licensing documentation,
