workbench报错问题?
浏览:2207
Linear Tetrahedral elements have been used in regions with linear materials.This is not recommended.Please consider changing your mesh setting to use a different element type in these regions.为啥用四面体网格不行啊?分析类型选择mechanical就可以,当选择explicit时就出现这个错误
