ABAQUS桩基计算不收敛问题,求问?
浏览:1950 回答:1
具体warning信息为:
Node 1300 instance soil-1 is common between the contact pair (assembly_soil-1_zhuang2-zs-sizhou, assembly_soil-1_soil-zhuang2-zs-sizhou). No constraint is formed for this node.
Warning message limit reached. No further warning messages will be reported.
Solver problem. Zero pivot when processing D.O.F. 1 of 49 nodes. The nodes have been identified in node set WarnNodeSolvProbZeroPiv_1_1_1_1_1.
The strain increment is so large that the program will not attempt the plasticity calculation at 44439 points
The plasticity/creep/connector friction algorithm did not converge at 2 points
Program is asked to invert a singular matrix
The strain increment is so large that the program will not attempt the plasticity calculation at 42610 points
诸如此类。。。。
我设置的桩和土体摩擦接触,桩底和土tie约束。不知何故,无法收敛。
ABAQUS桩基计算不收敛问题,求问?的图1
ABAQUS桩基计算不收敛问题,求问?的图2
王琰
用节点集合去设置约束和接触,这样可以避免边缘的节点同时参与约束和接触,形成过约束。另外根据你的提示信息,可能是某些节点没有纳入到约束中,有单元应变很大导致无法收敛
2019年3月6日
已采纳 评论 点赞 2
