ABAQUS桩基计算不收敛问题,求问?
浏览:1157 回答:2
warning信息如下:
Nodes 51314, 51310, 44833, 44865, 45417, 45418, 45577, 45651, 45652, and 51311 are part of a contact constraint, however all their degrees-of-freedom have been previously eliminated by other constraints. Abaqus will attempt solution and in case of failure will print appropriate messages regarding overconstraints.
Node 90 instance soil-1 is common between the contact pair (assembly_soil-1_zhuang2-zs-sizhou_cns_, assembly_soil-1_soil-zhuang2-zs-sizhou). No constraint is formed for this node.
诸如此类。。。。
我设置的桩和土体摩擦接触,桩底和土tie约束。尝试过点面接触和面面接触,均无法收敛。
网格点集合,不是点面接触
