与umat相关的abaqus错误? 20
浏览:1947 回答:3
使用abaqus关联umat做了一个简单的压缩实验,提交作业的时候第一次直接报错
Abaqus Error: Abaqus/Standard Analysis exited with an error - Please see the message file for possible error messages if the file exists.
重新命名作业重新提交作业,显示运行成功,但是没有分析结果
对比两个作业的log文件发现,报错的的作业那里多了如下的提示
forrtl: severe (24): end-of-file during read, unit 83, file e:\Myworks\temp1\texture.txti
Image              PC                Routine            Line        Source
libifcoremd.dll    0000000003E327EF  Unknown               Unknown  Unknown
libifcoremd.dll    0000000003E2C5A3  Unknown               Unknown  Unknown
libifcoremd.dll    0000000003E159AF  Unknown               Unknown  Unknown
libifcoremd.dll    0000000003D783E8  Unknown               Unknown  Unknown
libifcoremd.dll    0000000003D77022  Unknown               Unknown  Unknown
libifcoremd.dll    0000000003DBDAD1  Unknown               Unknown  Unknown
standardU.dll      00007FFB640B5C0D  Unknown               Unknown  Unknown
standardU.dll      00007FFB640E9A6C  Unknown               Unknown  Unknown
standardU.dll      00007FFB6408162A  Unknown               Unknown  Unknown
ABQSMAStaCore.dll  00007FFB5BD4A558  Unknown               Unknown  Unknown
ABQSMAStaCore.dll  00007FFB5C4D5CB9  Unknown               Unknown  Unknown
ABQSMAStaCore.dll  00007FFB5B81B85A  Unknown               Unknown  Unknown
ABQSMAStaCore.dll  00007FFB5BF712BF  Unknown               Unknown  Unknown
ABQSMAStaCore.dll  00007FFB5BF8EE45  Unknown               Unknown  Unknown
ABQSMAStaCore.dll  00007FFB5BF83C3C  Unknown               Unknown  Unknown
ABQSMAStaCore.dll  00007FFB5BF7FBC5  Unknown               Unknown  Unknown
ABQSMAStaCore.dll  00007FFB5BF67C2F  Unknown               Unknown  Unknown
ABQSMAStaCore.dll  00007FFB5BF66203  Unknown               Unknown  Unknown
ABQSMAStaCore.dll  00007FFB5CCE7EC1  Unknown               Unknown  Unknown
ABQSMAStaCore.dll  00007FFB5B731299  Unknown               Unknown  Unknown
ABQSMAStaCore.dll  00007FFB5C6076D3  Unknown               Unknown  Unknown
standard.exe       00007FF7909C38E9  Unknown               Unknown  Unknown
standard.exe       00007FF7909C154F  Unknown               Unknown  Unknown
standard.exe       00007FF7909D5F1A  Unknown               Unknown  Unknown
KERNEL32.DLL       00007FFB9A812D92  Unknown               Unknown  Unknown
ntdll.dll          00007FFB9D0A9F64  Unknown               Unknown  Unknown
求解答,在线等
传播正能量
再次查看没有输出结果但运行成功的log文件发现提示了一个错误 ***ERROR Message: nstatv .ne. numgrn*varsPerGrn。然后我再检查umat文件查找了这个提示
2019年3月24日
寒江雪_123
这是读取文件时遇到了文件的结束。例如,代码要求数据有3行数据,而实际输入文件只有2行。在某些时候,甚至输入文件根本不存在或是空白文件。此外,数据文件缺失某些行某些列也是较大的可能。当然,也可能是循环读取文件时没控制住。比如想读100行,结果写错了,读了1000行。有时候,可能是文件路径错误,导致实际读取了另一个空白的文件。或者文件扩展名被隐藏了,比如读取 a.txt,但实际的文件名却是 a.txt.txt
2019年3月24日
