全部悬赏
发布悬赏
专家入驻
注册领666大礼包
请问这个错误是哪里的问题,应该如何修改?
万分感谢
接触设置有问题,找不到master segment,重新设置接触,SSTYP和MSTYP选1、2或3,视情况而定
SSTYP:=Slave segment set or node set type. The type must correlate with the number specified for SSID:
EQ.0: segment set ID for surface to surface contact,
EQ.1: shell element set ID for surface to surface contact,
EQ.2: part set ID,
EQ.3: part ID,
¥150
¥9.9
¥5
¥15
¥60
免费
¥199
¥40
¥20
¥50
¥30
EQ.2: part set ID,
EQ.3: part ID,
