顶部banner
Logo 折叠
全网首发仿真工程师项目实训
下载app
返回旧版
首页 成长助手 小邻学院 社区 发现
职业认证 企业服务 行业会议
登录解锁更多功能
还没有账号?立即注册
技术邻
技术引领职场价值
电话
0571-86682823
商务合作
service@jishulink.com
  • 全部  > 
  • CAE仿真
ABAQUS动力显式计算时这种关于材性提示的错误该怎么处理啊?
浏览: 3692 回答: 1
Failed to regularize material data for material USTEEL02-HPB300. Please check your input data to see if they meet both criteria as explained in "MATERIAL DATA DEFINITION" section of Abaqus Analysis User Manual. In general, regularization is more difficult if the smallest interval defined by the user is small compared to the range of the independent variable.
Failed to regularize material data for material USTEEL02-HRB335. Please check your input data to see if they meet both criteria as explained in "MATERIAL DATA DEFINITION" section of Abaqus Analysis User Manual. In general, regularization is more difficult if the smallest interval defined by the user is small compared to the range of the independent variable.
Failed to regularize material data for material C30. Please check your input data to see if they meet both criteria as explained in "MATERIAL DATA DEFINITION" section of Abaqus Analysis User Manual. In general, regularization is more difficult if the smallest interval defined by the user is small compared to the range of the independent variable.
Failed to regularize material data for material C40. Please check your input data to see if they meet both criteria as explained in "MATERIAL DATA DEFINITION" section of Abaqus Analysis User Manual. In general, regularization is more difficult if the smallest interval defined by the user is small compared to the ran
ABAQUS
全部回答 (1)
USim 2019年4月12日
首先要明白,执行分析时,Abaqus / Explicit不会完全按照用户的定义使用材料数据;为了提高效率,所有以表格形式定义的材料数据都会自动正规化。
材料数据可以是温度、外部字段、塑性应变等内部状态变量。对于每个材料点计算,材料的状态必须通过插值确定,并且为了提高效率,Abaqus / Explicit将用户定义的曲线与等间距点组成的曲线拟合。
为了克服这个问题,您可以:
-改变公差(可以使用特定的材料类型来实现)
-完全关闭正规化(可以使用特定的材料类型来完成)
-添加/删除一些材料定义数据行(始终有效)
调整公差操作:
Edit Material对话框,选择General→ Regularization,即可重新定义公差。
2019年4月12日
评论 点赞 3
相似问题
查看全部
  • abaqus动力显式分析步混凝土塑性损伤模型不能适用吗?为什么会报错? 8个回答
    Failed to regularize material data for material C-FCK25. Please check your input data to see if they meet both criteria as explained in "MATERIAL DATA DEFINITION" section of Abaqus Analysis User Manua
  • abaqus为什么出现不满足abaqus用户手册中的材料定义的问题? 1个回答
    Error in job Job-1: Failed to regularize material data for material STAINLESS-STEEL. Please check your input data to see if they meet both criteria as explained in "MATERIAL DATA DEFINITION" section o
  • abaqus中出现报错材料数据规范化失败? 3个回答
    Failed to regularize material data for material ABQ_CDP_15. Please check your input data to see if they meet both criteria as explained in "MATERIAL DATA DEFINITION" section of Abaqus Analysis User Ma
推荐阅读
钢结构S1 ABAQUS经典金属弹塑性本构及模拟应用
1点 1点
¥100
Apex For Aerospace Applications Introduction
MSC Apex
免费
公路钢筋混凝土及预应力混凝土桥涵设计规范解决方案
敦樸DUNPU 敦樸DUNPU
免费
慧加新规范解决方案详解之大跨连续弯梁桥精细化分析(7DOF)
敦樸DUNPU 敦樸DUNPU
免费
混合弯头的流体流动与传热
混合弯头的流体流动与传热
CFD流 CFD流
免费
Abaqus子程序安装教程 Abaqus6.14.2+VS2013+IVF2013(附带安装包)
二十 二十
免费
北京华盛扬科技 北京华盛扬科技
¥9.9
Msc Apex For Aerospace Applications Idealization a
MSC Apex
免费
超大规模芯片电源完整性签核平台RedHawk-SC应用分享
Ansys中国 Ansys中国
免费
ALTAIR ALTAIR
免费
结构仿真职业规划与学习路线
结构仿真职业规划与学习路线
技术邻直播 技术邻直播
免费
人工智能工程应用实例: 发动机排放数据学习及预测
IDAJ中国 IDAJ中国
¥99
Altair二次开发答疑&典型案例解读
Altair二次开发答疑&典型案例解读
ALTAIR ALTAIR
¥10
MATLAB/ADAMS求解动力学
MATLAB/ADAMS求解动力学
伟_sss 伟_sss
¥25
基于OptiSturct的线性静力学分析和尺寸优化
Leon_sun Leon_sun
¥10
AQWA软件企业培训(3)  通过ANSYS-APDL建立半潜平台混合模型及混合模型的拖曳力线性化
Nutshell Nutshell
¥30
TurboTides TurboTides
免费
UG编程零基础入门到精通以及优化刀路教程
UG编程 UG编程
免费
abaqus座椅滚轮拉脱力强度分析
abaqus座椅滚轮拉脱力强度分析
任总 任总
¥90
十分钟快速进行电子产品结构设计方案评估
十分钟快速进行电子产品结构设计方案评估
技术邻直播 技术邻直播
免费
