仿真工程中出现的待求解问题?
浏览:1130
仿真工程中出现的待求解问题?的图1
wrong # args: should be "::NVH::HmUtils::GetSolverId str_entType n_ent"
    while executing
"::NVH::HmUtils::GetSolverId props $componentID -byid"
    (procedure "desvarT" line 209)
    invoked from within
"desvarT $fileout $logFileOut"
    (procedure "desvar_macro::export" line 238)
    invoked from within
    invoked from within
".mainWindow.buttonFrame.exportButton invoke"
    ("uplevel" body line 1)
    invoked from within
"uplevel #0 [list $w invoke]"
    (procedure "tk::ButtonUp" line 24)
    invoked from within
"tk::ButtonUp .mainWindow.buttonFrame.exportButton"
    (command bound to event)
请问这是啥情况
