Adams Insight进行硬点优化失败?
浏览:1310
报错如上图,有知道怎么解决的么
---- START: ERROR ----
Static equilibrium analysis has not been successful.
The maximum number of iterations 25, has been reached.
For the last attempted iteration:
The equation with the largest error was model.testrig.left_vertical_controller Comp = 0 Error = 0.000000
The variable receiving the largest increment was model.active_suspension_V3.jolrev_lca_body_rev Comp = 3 Delta = 26.660248.
---- END: ERROR ----
Static Solution failed to converge
End Static Solution
Simulation failed
Initial Static Sim. Not Successful
