ansys无法计算如何解决啊?
浏览:1207 回答:7
 *** ERROR ***                           CP =      55.203   TIME= 09:53:08
 There are 36 small equation solver pivot terms (e.g., at the UZ degree
 of freedom of node 4238).  Please check for an insufficiently
 constrained model.
Zl1232140
检查模型约束是否正确施加。
2019年4月29日
评论 6 点赞
