abaqus在执行作业的时候报错,错误代码为1073741515请问怎么解决? 70
浏览:2835
Error in job Job-1: The executable pre.exe aborted with system error code 1073741515. Please check the .dat, .msg, and .sta files for error messages if the files exist.  If there are no error messages and you cannot resolve the problem, please run the command "abaqus job=support information=support" to report and save your system information.  Use the same command to run Abaqus that you used when the problem occurred.  Please contact your local Abaqus support office and send them the input file, the file support.log which you just created, the executable name, and the error code.
Job Job-1 aborted due to errors.
