我在做瞬态分析,现在出现两个错误,不知道怎么回事,求大神支支招
浏览:580 回答:1
1.
 Element 1 using isotropic material 1 has a value of Poisson's ratio of
 11540 which must be greater than -1.0 and less than 0.5.
2.
 The step data was checked and there were errors found.
  Please check output or errors file ( F:\moxing\shangke\file04.err )
 for messages.
Zl1232140
第一个错误是泊松比设置错误,一般在0-0.5之间,第2个是分析步设置有误,检查分析步设置。
2019年6月25日
